spv7hqfj
Block Compare Instruction
8 posts in this topic
Is there a Block Compare Instruction like the one in Omron PLC for Mitsubishi PLC?
If the Omron PLC is BCMP (68), then what is the name of the instruction on the Mitsubishi PLC?
I tried to use BKCMP in the Mitsubishi PLC, but the way it works is not the same as the one in Omron PLC
Which PLC are you using ?
Q002U
Looks like you want to search if some data exists in Block of words.
Try the search function SER(P), DSER(P)
Or just use 16 lines of code until something better comes along.
Simple and easy to read.
Ya very simple, but if u want to use 1000 compare???
Then make a function block or use a for-next loop?
Or use 1000 lines of code?
Do you want to use 1000 compares???  :)
