Dixon
Zebra ZT230 Ethernet/IP
3 posts in this topic
Does anyone have an .eds file for the Zebra printers. I need to use ethernet/IP from a CJ2MCPU31
It doesn't appear they are Ethernet/IP compatible. Generally, the device manufacturers will distribute the EDS files if they are available.
Checked it also, and as IO_Rack said it doesn't have Ethernet/IP capability. You can, however, use TCP/IP or more likely called as Socket Service TCP in Omron manuals.
To bad though the CJ2M-CPU31 CPU unit does not support Socket Service. You need to purchase CJ1W-ETN21 module and plug it in to the CPU in order to have Socket Service capability.
Another option is to use RS-232 serial (Z230 manual mentioned that it supports RS-232) which considerably cheaper since you just need to buy CJ1W-CIF01 option board to be plugged on the CJ2M-CPU31 CPU, granted that you haven't use it for other connection
