Posted 21 Feb 2018 We are working on a project that operates a set of 4 pneumatic solenoid cylinders using GX developer PLC type FX1N (C). when the desired sequence is selected, the cylinders operate in the order needed until they reach the counter. the counter value increases by 1 but does not run through the sequence again and cant move forward until the value of the counter is reached. any help on this would be greatly appreciated. Share this post Link to post Share on other sites
Posted 21 Feb 2018 You can use a compare CMP to look at the value of the counter. Read up on the instruction. It gives 3 M coils. Less than, equal to, greater than. Share this post Link to post Share on other sites
