Posted 31 Jan 2018 Hello, i have a problem with B&R Automation Studio 4.3 installed on PC W10. The software was installed without error and for a month it's was used with a new series of B&R's plc. From the end of December until now, only this version always return an error only in the windows events, when i try to lanch it. The error is about module mfc140.dll with 0x3b4c error code. All software upgrades were do (Visual Studio and a SP of AS 4.3) without results. B&R support can't re create the same conditions, so i must to use a different PC with W7 for use AS4.3. Someone have or had a similar problem ? Best regards, Ennio Share this post Link to post Share on other sites
Posted 31 Jan 2018 Have you searched to make sure that DLL file is on the PC? Can you check a PC where it works and see if the size or file date are the same or different? Quick Internet search led me to this: The mfc140.dll file is part of the Microsoft Visual C++ 2015 Redistributable Update 3 RC package.To resolve the issue: Download the package from Microsoft Visual C++ 2015 Redistributable Update 3 RC. Install the package by running the downloaded .exe file. Share this post Link to post Share on other sites
Posted 31 Jan 2018 (edited) Hello Crossbow, thak you for your reply. I had already done all thing that you suggested me, without good results. I also deleted all AS4.3's register in windows, uninstalled and reinstalled all packet many times. The error it's always the same but only in windows events. The B&R support request me to send my PC to the factory for more test or send a virtual copy with VM. Best regards, Ennio Edited 31 Jan 2018 by ETR Automazione srl Share this post Link to post Share on other sites
