21 posts in this topic
Hello everyone,
can u help me out please, quite urgent !!! :(
i have GS2107-WTBD HMI display along with FX5U-80MT-ESS, i had one of HMI designs made on GT designer 3 by earlier designer (not in my contact now). i uploaded the graphics to HMI module and later it stuck to the initial LOGO screen and doesnt move further, moreover the HMI is not communicating with PC. i suspect it had remote password with it
how can i remove this issue or hardware rest the HMI with factory defaults
guidance required
I don't think that you have a password issue just that there is no comm with the PLC.
Can you post the HMI ethernet settings and those of the FX5U?
Edited by Gambit
presently i am just trying to use USB cable between PC and HMI & no FX5U is interfaced, here at least new graphic projects should have been uploaded, but it shows no communication and gives error and the HMI screen is frozen to Logo 'GOT SIMPLE'  Please see attachments
Thank You
Is there any kind of Hardware Rest Available or any setting where i can set factory default parameter in HMI ????
Well you should be able to download the firmware this would set it into factory settings. But you seem to have a connection problem.
What does the Device manager on your PC show when you plug in the USB cable ?
On this HMI i uploaded 3-4 sample screens and all worked well ! but when i tried this another designer's project, the next time HMI when was reset it started showing this issue...
HMI screen Freezes to this startup logo screen it doesnt move forward
Have you tried Rebooting the HMI and sending a new project when it's rebooting it should start when it's ready.
Also can you read the project from the HMI?
Edited by Gambit
yeah This worked ! i gave write command and powered on at same time !!!
it is updating to new project now ! this worked
Thanks a ton !
Anytime
but came up with new issue !
in my editor this is the basic sample design and i made as described in training manuals
i made 2 switches and one bit lamp
on HMI switches are visible but the bit lamp and all output devices like numerical disply is not on Physical HMI, even simulator of GT3 shows all components
You don't have comms to the FX5 that why they are not shown.
Add a light on device SM412. When you have comms than that should start turning on and off
Edited by Gambit
If you can't get the comm running post the pictures of the comm settings for FX and GOT
i am unable to connect FX5U and HMI
kindly suggest measures for successful connection any tutorial is there ?
try changing the GOT communication port to 5556
Steve
can anyone please mention procedure for FX5U - GS2107 Ethernet communication
please send a screen capture of CH1:Melsec FX from GT Designer.
You have used the wrong driver for FX5U, you have to use the MELSEC IQ-F driver instead of the FX driver. It will also change the port number to 5001.
