Posted 3 Nov 2017 Hello. There is a controller FX5U-32MP in the presence, the inscription "CC-Link IE Field Basic" and the Inverter (FR-A840-00170-E2-60) near the connector, the inscription "CC-Link IE Field Basic" on the front panel. I set up both devices according to the instructions. It turns out to read the state of the inverter (state, frequency). And I can not manage from the controller. Already all the settings that could have changed. Can you scribble what is wrong? p.s. Sorry for the bad english. Share this post Link to post Share on other sites
Posted 3 Nov 2017 Hi Neverov Can you control from the controller (PU). Make sure that parameter 79 setting is in PU mode. The reason for this is because the Mitsubishi drive sees it as a on-board controller. Now, next thing to check, is parameter 550 and 551. Keep 550 as default, but change 551 to 5. Check the manual why. You should now be able to control from the PLC. Share this post Link to post Share on other sites
Posted 3 Nov 2017 Sounds like you have set up everything accept for the control master ip adres in the inverter. pr1449, 1450,1451,1452 Share this post Link to post Share on other sites
Posted 6 Nov 2017 Does not work. Here is the list of parameters that are involved (most of them are by default). I will be grateful if you look and tell me what's wrong. 1.pdf Share this post Link to post Share on other sites
Posted 6 Nov 2017 (edited) 550 NET mode operation command source selection to 5 551 PU mode operation command source selection to 3 According to your sheet pr 1434 is set to 1 instead of 192 !!!! Also this is set as the control station: 1449 Ethernet command source selection IP address 1 0 to 255 192 1450 Ethernet command source selection IP address 2 0 to 255 168 1451 Ethernet command source selection IP address 3 0 to 255 1 1452 Ethernet command source selection IP address 4 0 to 255 1 But according to your screen captures above the master is 192.168.1.150.. Edited 6 Nov 2017 by Gambit 1 person likes this Share this post Link to post Share on other sites
Posted 6 Nov 2017 (edited) 550, 551 - Installed. 1434 - A typo in the inverter wrote correctly. 1449..1454 - I thought that I correctly set the range of IP addresses from which you can give commands. Thank you very much. Has earned !!! Edited 6 Nov 2017 by Neverov Share this post Link to post Share on other sites
