haledwa
WAGO e!cockpit Network Scan no Ethernet
Hi All
I'm struggling to a PLC using WAGO's e!cockpit software which I am new to.
In the network tab when I click to select "ETHERNET" from the "Scan Settings" area all that comes up is a drop down with "update selection" which does nothing.
As a result I cannot scan for the PLC's on my network.
Has anyone got any ideas on this issue.
I'm running on windows 10, could that be a problem?
Edited by haledwa
Found the answer, e!Cockpit does not work in windows 10 as of yet. Windows 7 works perfectly.
Bonjour, j'ai exactement le même problème sauf que je suis sur windows  7 ! Après plusieurs scan etc impossible de trouver mon automate , quelqu'un aurait il une solution , s'il vous plait.
Je suis connecter en câble ETHERNET directement relier de l'automate a mon PC.
