Posted 29 Oct 2017 Hi! I'm working with a VM with rsview32, rslinx and rslogix500/5000 inside; I can comunicate with all the PLCs in the net using rslogix and rslinx (IP). When I start my RsView project, it looks all in blank, I mean like RsView can't comunicate with any PLC, however I can program/go on line/download/upload any PLC using rslogix. I saw rslinx configuration and all the PLCs are available. Any suggestion? Share this post Link to post Share on other sites
Posted 29 Oct 2017 Did you set your runtime path in your HMI project? Share this post Link to post Share on other sites
Posted 29 Oct 2017 7 minutes ago, Armadillo852 said: Did you set your runtime path in your HMI project? Where can I find this option in RsView? Share this post Link to post Share on other sites
Posted 30 Oct 2017 Have you read the manual for RSView32? Post screenshots with the problem or where you are stuck, that will get the best response from the forum. Understand that the project is built for the HMI to communicate with the PLC; if the compiled, downloaded HMI project does not allow the HMI to communicate with the PLC, then the HMI project communication path is not set properly. Chapter 2 http://literature.rockwellautomation.com/idc/groups/literature/documents/um/vw32-um001_-en-e.pdf Share this post Link to post Share on other sites
