marcinmrag
edit time variable in Recipe NA HMI
11 posts in this topic
Hello,
I would like to use one recipe parameter which is time variable. But I have problem to use time variable in HMI recipie. Can someone help me with this? How i can handle this? I can put value in INT but how can i convert it to TIME in PLC program?
Look for NanoSecondToTime, or MillisecondsToTime instruction in NJ. You put LINT valeus of Timespan in Nanoseconds / Milliseconds in HMI then convert it to time by program.
If your time requires Hour, Minutes, Seconds, you can put each individually then calculate the total value in Nanosecs / Millisecs before converting to Time.
Alternatively you can implement a Custom Time Keypad in NA to input Time values directly to Time variables, although it's more complicated (requires VB Scripting)
@innoaloe
Do you have an example of using the custom time keypad to edit the time variables directly?
This would be very much appreciated.
Hello !
I found this topic while searching an easy way to edit TimeSpan tags in an NA-5 HMI.
Is the EditVariable() method the only way to use a TimeSpan keypad?
Using a Press Event is somewhat clunky because it doesn't seem we can pass arguments to methods called that way.
I have 16 PIDs I need to make configurable via HMI and their I and D gains are in the TIME/TimeSpan datatype.
I'm not aware of an elegant method. I don't use the TimeSpan data type in the NA. I create Functions in the controller that will convert REAL to TIME and TIME to REAL (in seconds), then enter my time in [Seconds].[Fraction of a Second].
The commands in the controller are NanoSecToTime and SecToTime, there is no millisecond variant.
This is correct. For the purposes of reading and writing time to/from the HMI, I create the following custom Functions:
REAL_TO_TIME
REAL_tmp:=In*REAL#1000000000;
LINT_tmp:=REAL_TO_LINT(REAL_tmp);
Out:=NanoSecToTime(LINT_tmp);
TIME_TO_REAL
LINT_tmp:=TimeToNanoSec(In);
REAL_tmp:=LINT_TO_REAL(LINT_tmp);
Out:=REAL_tmp/REAL#1000000000;
I am new to SYSMAC.
I came across this trying to work out how to convert time to real. Some handy hints thanks.
Real to time is simple with "MULTIME" function. I am surprised nobody mentioned it.
Simply put time units for the first variable eg T#1s or T#1h. Then put real value (or any data type) in second variable and output will be correct time variable.
REAL_TO_TIME
TIME_TO_REAL
Thanks IO_Rack. I was looking for this solution. Works perfectly.
