wouter94
triggering popup window with variable
i'm working with vijeo designer and i have a problem with popup windows. I'm trying to make a popup window appear with a variable. A bool to be exact. I want that a popup window appears when the bool becomes 1. But so far i haven't found a way to do that. Can someone help how I could do that? It's the meaning that that bool becomes 1 when there is an error and that the popup window appears then to let the user know there is an error. Or does annyone have a better idea?
Hi wouter94,
You can use text display to warning error.
yes, but I find that pretty annoying because when you want to make changes to the panel you have to move al those text displays to the side. And the same message has to appear on every panel and i have 19 panels. So if i could do it with a popup window I just have to make 1
You will have to use actions. Create a new conditional action and tell it which popup to open or close
