Posted 29 Jun 2017 Hi all, I have been getting to grips with the different graphic displays in CX One Designer but I am having trouble trying to produce a table which shows column one as a label and column 2 as data value that I am polling from a Modbus slave. From what I have read/tried the data block table seems to require a csv as the data source and I cant seem to achieve what I want with the standard table. If anyone can advise how I might be able to achieve this I would be extremely grateful. Below is the sort of thing I'm hoping to achieve but in a table format: Bearing 1 Temperature 80°C Bearing 1 Vibration 0.2 mm/s² Bearing 2 Temperature 82°C Bearing 2 Vibration 0.2 mm/s² Share this post Link to post Share on other sites
Posted 30 Jun 2017 Are you able to elaborate at all? I have created a table but It seems I can only assign registers to each cell. I want the left column to be static labels and the corresponding polled values to be in the right column. If you have a link to any guidance on using tables that would be great! I cant seem to find much guidance on using the tables in the manual. Share this post Link to post Share on other sites
Posted 30 Jun 2017 I am pretty sure the table only shows data. For labels, you need to make them on the screen. Share this post Link to post Share on other sites
Posted 30 Jun 2017 Labels can be added to the table. See ppt and lab below. 06b - Tools - Repeat and Table 111304.ppt 06b Repeat and Table Functions 1061705.doc Share this post Link to post Share on other sites
