Posted 20 Apr 2017 Hi, I'm new in the forum. I kindly request a help for an idea on how to access the NOR0200 module without an issue. The problem is that I could not access the webpage with correct display. I am currently using Windows 7 as my OS, Java 8, and IE11. As the manual indicate, the minimum IE version required is IE6, however I could not install those version same as to IE8 with the current OS version I have. I tried the NOR using IE10, 11 and 12. I also tried a lower version of Java 7 update 51 but all the java related display does not display nor even show prompt of allowing to access. Some of the message display in setup were also messy. I would be very grateful if somebody could help me regarding this. Thank you very much. Best Regards, Raymond Share this post Link to post Share on other sites
Posted 21 Apr 2017 Hi there, I use Win7 IE9 to access this module and sucsessfully. 1- The module must be configure using UnityPro, fill-in the IP-addr completely. 2- Build your configuration 3- After successfully, please re-start the PLC (switch OFF the power connection and switch ON again). 4- Open your IE, go to IP-addr (based on the step-1 above). There is a user name (default) = USER, password (default) = USER. 5- Follow the manual book of NOR0200 for the next step. good luck, Azdi Mus Share this post Link to post Share on other sites
