imhassaan
MITSUBISHI GOT1000
14 posts in this topic
GT Designer aka GT Works
Kindly Check whether you will be able to open this file format or got some version error ?
Edited by imhassaan
Wasn't able to open it. Which GOT type should this project be from ?
Actually i want to do some modification in this program. The original Screen is designed by some international company but we want to do modification locally.
i take this backup from GOT1000 using data tranfer.
then i take other backup using gt designer which file is attached now.
GOT1000.GTW
I have GT designer 3 version 1.37P but i wont be able to open project
I cannot find any Version 2.79H. any software to convert this to GT Designer 3 or any other way ??
Regards
you need to retrieve it with GT designer 2 (classic) It should be on the GT designer 3 dvd.
I haven't got it installed I can check tomorrow if I can open the files
Edited by Gambit
Ok  I am trying now. But also i will wait for your reply tomorrow.
Thanks
You need GT designer 2 latest version is 2.107. t only installs on a 32 bit windows so I can't check your files
From where i get the GT designer 2 2.107 ?
Is there any link for trial version of gt ddesigner 2 version 2.107 ?
Thanks
Not that I am aware of. I would just contact your Mitsubishi dealer if you've bought GT Designer 3 they will probably give you the older version
Actually i am using the trial version just because of too much different versions of software. now my first target is to just open the project
