Chickenkiller91
Invert scale 0-990 --> 990-0
Hello.
I have a D word number 0-990. I would like to convert it to 990-0.
So i need a function which shows me 0, when the D100 is 990, and shows me 0 when the D100=990. And of course for the between values also. Calculating continiusly.
Help is much appreciated :)
I guess the function i would need, is y=(-x)+990
Is it possible to implement functions in cj2m ?
Not per se.  However, if you create a Function Block and use the same instance name over and over, it will behave as if you had created a Function.  Meaning that it will use the same memory for all instances of the Function block with that name.  It is not an issue in this case because it is a simple math formula that always provides the same result when a particular number is input (it does not depend on past executions to determine a result).
2 hours ago, Chickenkiller91 said:
Hello.
From 990, substract your value that you want to invert and output to the word you want the inverted value.
@pfort He had already figured that out in his second post above.
Yes, I meant, no need for a function block (As I interpret his post). He only need a substraction instruction.
So, Chickenkiller, Michael is right. You said that y=(-x)+990 and I said that y=990-x. It's the same.
What I say is you only need a substraction instruction, available in any PLC.
Edited by pfort
