Posted 9 Apr 2017 (edited) As part of a startup initialisation I want to set some 400 memory tags to a string value. I use this routine: Public Sub WriteValue(val As Variant, TagName As String, Fm As Display) Dim TG As TagGroup Dim WriteTag As Tag Set TG = Application.CreateTagGroup(Fm.AreaName) TG.Add TagName Set WriteTag = TG.Item(TagName) WriteTag.Value = val End Sub It Works well - but it is slow. Making about 400 writes takes 40 seconds. I thought maybe the creation of a taggroup before every write was slow (like it's done with the use of this WriteValue routine), so I tried making a taggroup with all 400 tags first, set active=true for this taggroup and then do all the writes. But it's equally slow. How do I speed up the writing of such memory text tags? I have a had similar read-issue - here the many individual reads is slow, but if I create a large taggroup with active=true - then reading is fast. I use FTview SE 7.0 on Win 7-64 Edited 9 Apr 2017 by Jake104 Share this post Link to post Share on other sites
