mazen_abs
how to connect got2000 with FX3G direct through ethernet ?
13 posts in this topic
could you please help me to know how to connect got2000 gt2104  with FX3GE  direct through ethernet
thanks in advance
FX3GE have a built-in FX3U-ENET-ADP on communication channel 1, so you need set up in plc enet module. Also need configure got.Try this settings.got.thumb.PNG.10a46eaaec6d9b23a22611a02ffx.PNG.7efe5ab1d24716ee4f61ec0f2322e0d9.
Edited by Clear.Mind
thanks for your reply
,but it still doesn't work
Change the port number to 5556
thank you mr Gambit  ,
but it still not working , could you please help me , if  have files explain the connection steps with examples
thanks in advance
Ok you are using the FX3GE so the port should be 5556 (port 5551 is for the ethernet module on the right side)
Can you change the GOT station number of the GOT to 2. (You should prevent having the same station numbers for GOT and PLC.
Lastly Did you create a MELSOFT connection in the ethernet parameters in GX Works 2?
Edited by Gambit
I did
and herein snapshot for plc &  GT setting
Looks fine.   Are you connected to a switch or is it a direct cable between GOT and FX?
If it's switch is anything else connected ?
Can you ping the PLC from the GOT or vice versa?
What do the ethernet diagnostic say from the PC side?
Edited by Gambit
Can you ping fom GOT to PLC? This is a function you can access via the utilities.
Have you tried another cross cable ?
sory, would please clarify what you mean by ping function
Do you know how to create a button to get to the utillities of the GOT
5 hours ago, mazen_abs said:
Direct connected
As @Gambit is also saying: Did you use a crossed Ethernet cable? You need a crossed Ethernet cable if directly connected.
