ThePLCPeon
Issue changing IP address of a Q03UDECPU
Hello, I am trying to change the IP address of the plc mentioned in the title. I am using GX Works2 and in the project tree I navigate to the PLC Parameter option which displays various tabs and settings for the plc. I select the tab called " Built in Ethernet Port Setting " this then displays an ip address setting box with " IP Address " " subnet mask pattern " and " Default Router IP Address "
They are currently set using 192.168.1.50    255.255.255.0     and    192.168.1.244 Respectivley.
This all works fine and communicates etc, my problem arises when I want to change the IP address to 192.168.0.50, when i try to end the window it produces a popup notification saying the following;
" Incorrect setting value for IP address
Please set withing range of 0.0.1.1 to 223.255.239.120 "
So is there someway to allow the IP address I want to set it to? Or is there some kind of limitation on the address I can use on this plc?
Cheers.
Hi,
Strange. Works fine here.
/Dariusch
Aha...
If you have enabled the "IP Packet transfere setting" you get the error.
You have to check if your application can run without this setting.
/Dariusch
