DennisP
FactoryTalk View DINT to ASCII conversion
15 posts in this topic
Would someone please help me how to convert an integer to ascii?   For example if the output tag is an ascii string, of 3 characters and my numeric input is integer.   When user input a value of 5, I would like the input value to be convert and assign to output ascii string tag of "005".  How do I set the conversion format in either tag assignment or tag expression?
Edited by DennisP
When you converted the DINT with value 5 to the ACSII string tag, what did the ACSII string tag read?
ASCII tag reads as "5", I would like to format it to be 005, or if numeric input is 15, I would like ascii string tag to read as "015"
Then you need to examine the string tags length then set up two dummy string tags with "0" and "00" to then concatenate the first result with to a third string that is transmitted out.
Or with comparative logic, i.e. DINT LES 9 you could insert "00"
DINT is between 10 and 99 then insert "0"
Greater than 99 don't insert anything.
Edited by pcmccartney1
I have tried as an expression but it doesn't seem to work.
if dInput < 10 then sOutputTag = "00" + dInput
else if dInput < 100 then sOutputTag = "0" + dInput
else sOutputTag = dInput
The reason you expression doesn't work is due to a mixing of data types.
Copy and paste the following into empty rungs:
DTOS Value StringInit
BST LES Value 100 BST LES Value 10 CONCAT String00 StringInit StringOut NXB LIM 9 Value 100 CONCAT String0 StringInit StringOut BND NXB GEQ Value 100 COP StringInit StringOut 1 BND
Thanks.  Your logic would work if applies to an AB PLC rung.   However I am trying to apply the logic to AB FactoryTalk View Studio for AB PanelView Plus display.     I figure there is something wrong with my logic when assigning DINT to String.  However I am not sure how to do in an FT View expression
Let me amend that statement, there is no equivalent to a DTOS (DINT to String) in the PV+.  You really are better off doing the logic in the PLC.
Sorry for being a beginner but where do I get the expression builder to access and convert PV+ database tag?
To my knowledge, there is no means to convert a DINT to a string in the expression builder.
Maybe someone else here knows a way to do that.
Still think you are better off doing it in the PLC.
Try this,
Change the object on the screen to a String Input Enable, on the "String" tab, change the number of characters to 3 and then change the Fill to zeros.
I did use that approach, unfortunately the string input doesn't support left fill zero, as in numeric input, but it does right fill zero instead.
For example, input string of "1" will get fill with "100" instead.
Then I'm out of ideas, hopefully one of the true brainiacs will have an idea for you.
Thanks again for coming up with ideas.   I probably will have to implement the conversion/formatting logic in the PLC side in this case.
Is it SE or ME?  Is there a PLC involved?  If so, what model?
I have to sleep.
If you're using SE, you can convert ASCII characters to their decimal equivalent by using the Asc() function in VB, and vice versa using the Chr() function.
If you're using any controller that uses RSL5K (or now Studio 5K) you can use a DTOS instruction to convert a string to a DINT.
Edited by adohm
Clarification on program use
