Johanb
can you compose a MODBUS telegram with a macro ?
I am controlling a Danfoss FC051 with a OMRON CJM1 plc using a modbus master program .
the control is done with a OMRON NS5 screen that reads the parameter value .
to change a parameter I need to send a modbus telegram to the FC051 with a specific Node address .
Can this be done with a macro that is activated by changing the value in a input box ?
a example would be most appreciated
Which port will you use?
Hallo Jay .
because I want to program 1 screen for one range drive I am using FTP/IP communication .
I have included a file written with Open Office  and Microsoft  Office .
NetWork Setup.doc
NetWork Setup.odt
Quote
FTP is File Transfer Protocol.
Do you mean EIP protocol?
What is DP Protocol?
Mistake 1 : I use IP number to communicate between the screen and the PLC .
using a adapted program MODBUS master : see File SV357.
Mistake 2 : forgot to remove the DataProtocol V1 what is a Devicenet protocol for Danfoss inverters .
I am using Modbus for the control off the FC051 Danfoss drive .( see file ssp you need MCT10 from Danfoss to read the file  )
In the prog you may find the text " Smart Logic" what is a small program that runs in the Danfoss Drive
schietbaan H&T-2setupsV10.zip
SV357O.ZIP
SV357-NS5U.ZIP
