Jake104
FTview 7.0 - ho do I run a VBA routine every 5 seonds?
2 posts in this topic
How do I set up a timer-based event?
I would like to run e specific VBA routine every 5 seconds. How is that done?
Can I somewhere define a timer on the FTview-application or on the Display to run a routine every 5 seconds?
In iFix of WinCC I can just define a timer like this - and I looking for the equivalent in FTview.
Events have an 'interval' function that allows you to fire an event after a particular interval of time.
INTERVAL("5sec") I think will work. You may have to play with using the quotes or not.
UPDATE: Actually I don't think this will work as I stated above. If I'm not mistaken, Event Detector files run on servers, not clients.
So instead use my other answer I gave you for events on clients and simply use the system\seconds HMI tag to populate a numeric input.
The 'Change' event for the numeric input will foire every second. Just use a MOD 5 function to determine every 5th change.
Edited by Filthy McNasty
UPDATE
