Posted 12 Dec 2016 Hi All, I need to add an 1756-IF8 to my controlnet on a L61 PLC. I have already added the device to RSLogix 5000 and inhibited it for the moment. I have RSNetWorx for Controlnet version 11 as it is an older project. What do i need to do to schedule this device on controlnet? I've been told you need to be online with RSNetWorx and then do an upload, what else do you need to do to schedule this device. Any help greatly appreciated. Thanks Stu Share this post Link to post Share on other sites
Posted 12 Dec 2016 You do have to be online. You have to start an edit after the initial browse. Make sure the modules are NOT inhibited before you schedule your network. Adding these new I/O modules will require that the L61 be placed in Program/Remote Program before the scheduling can take place. Remember to check to see that the UMAX is set to a valid node number. Share this post Link to post Share on other sites
Posted 15 Dec 2016 On 12/12/2016 at 3:10 PM, Filthy McNasty said: You do have to be online. You have to start an edit after the initial browse. Make sure the modules are NOT inhibited before you schedule your network. Adding these new I/O modules will require that the L61 be placed in Program/Remote Program before the scheduling can take place. Remember to check to see that the UMAX is set to a valid node number. Did this something similar to this onsite and it worked a treat Share this post Link to post Share on other sites
