RET-USMC
ML1400 AB_ETH_TCPIP DHCP MSG Help
2 posts in this topic
Hi,
I Think I Might Have 1 Problem(s) w/MSG Logic, Never Used MSG's Before.
 This Is a Home Training Project, To Get This Far Took Some Learning Curve.
 HMI Requires w/Ethernet-ABEN (Allen Bradley Driver) MSG's, Bootp Not Supported w/ABEN
 AB.com Seach For ABEN Nothing/Maybe w/a Tech Connect Acct, Which Work No Longer Supports.
Thanks To All For Viewing & Helping
Already Established a DF1 RS232 Network w/ML1400 & HMI Works Perfect
 Also a WiFi Only w/PC & ML1400-Working
  Wanted To Attempt The Ethernet Network w/HMI-Ethernet/Uncharted Waters!
Using w/The HMI Ethernet Port:
PLC Sending/Write-MSG Data, Present In Nxx:x Image Table
 CTC-P41/HMI: Allen Bradley Driver [ABEN] Correct Version/Verified w/Parker Automation/CTCUSA
    (Interact v7.0  : EX-83153-611  EX-83151-613)
  HMI Not Displaying Write Data.
   MSG Write Error Code (Hex)d6 (Reserved w/AB)
MSG-READ Same Thing, Not Showing In PLC Nxx:x
  MSG Read Error Code (Hex)d6 (Reserved w/AB)
RUN/CMD/IPConfig /all
RS500 Ethernet Network [DHCP] Working/All Nodes-0-2(HMI) 10/100-T Based-TX(F/H) Incl: Pinging
 On Both RSlinks [v2.54] Networks, AB_ETH & AB_ETH_TCPIP
From PC-ETH/LinkSys WGT54GS v7.0/Hirschmann Spider 5TX Rail Switch/ML1400-CH1/CTC-P41 HMI/ETH-Port
   (Rail Switch, 5 x 10/100BASE-TX, TP cable, RJ45 sockets, auto-crossing, auto-negotiation, auto-polarity)
Addtl Specs:
 ML1400 (Label) 1766-L32BXB Ser B FW 11
        RS500/Processor Status/Proc [Tab]
         OS Series B
         OS FRN    13.0
         Processor Cat# 1766-LEC
         Processor Series B
         Processor FRN 3.0
        RS500 v8.31.01 (CPR9)
        RSLink v2.54
        CTC P41-3T7-I1-2A3 (10" P266Mhz,32bit,CF&IDE-SSD, CDROM, 144MB Floppy, 4 Expansion Slot BUS)
UPDATE: 11/10/16 Solved
Using Wrong Allen Bradley (ABEN) Driver, PLC Type Selection For Ethernet Network
Was Using ENI-MICROLOGIX"  HMI Screen Display ( ! ) = No Send/Recv Eth Data
Correct PLC Type MICROLOGIX 1100 For The MicroLogix 1400 Processor,
Use  Indirect Addressing, No RS500 MSG Read/Write PLC Logic Required
PLC Bit To HMI Bit (Tag Editor) Tag Editor Same As RS232/DF1 SLC5          ABEN\1$N7:0,0
Edited by RET-USMC
Problem Solved
MSG command is for PLC to PLC not PLC to HMI
