Posted 20 Oct 2016 (edited) I am having problems expressing an ANALOG OUTPUT 16bit INT word (0-10V Proportional Valve Voltage) as a REAL decimal number. From my understanding the word is divided into 2 (8bit) bytes...one representing the whole number value and the second the decimal value. We're using BL20 I/O Module (german therefore LSB first I believe). I need to MOV/COP (read) the value, CONVERT it into a REAL number, Manipulate the REAL VALUE, then CONVERT the MANIPULATED REAL Value back into a 16bit INTEGER & WRITE the NEW Integer Value into Proportional Valve Voltage Location. I also have a similar situation regarding our Incremental Encoder. In this scenario the pulse count is obviously a whole number (no decimals) where 4 (16bit) bytes represent the REAL Count Value.. I have read other posts on similar conversion topics and understand the general premise, but I'm having problems specifying write parameters.. - i.e. writing bits 0-7 from an INT into SINT[0] (HIGH BYTE representing the whole # value? ) and writing bits 8-15 into SINT[1] (LOW BYTE representing the decimal value) THEN CONVERTING into REAL # (Voltage fed to Proportional Valve) ...manual section... page 282&283 http://pdb2.turck.de/repo/media/_us/Anlagen/d300717.pdf - i.e. writing bits 0-15 from INT[0] , INT[1] , INT[2] and INT[3] into a LINT (not sure if correct) THEN CONVERTING into REAL # (Encoder Count) ...manual section... page 17 (current count value) http://pdb2.turck.de/repo/media/_en/Anlagen/D301224.pdf ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED... project file if interested.. https://sites.google.com/site/lyncedrgb/eva/untitledpost-2/StellaPLC.ACD Edited 20 Oct 2016 by jake4eng Share this post Link to post Share on other sites
