Pankaj Jangid
Java PLC communication over USB-to-RS232
2 posts in this topic
I am trying to communicate with Omron PLC CP1E-N40DR-A over USB-to-RS232 cable, using a Java program. Following is my basic code—
    public void startComm() {
        PrintStream os;
try {
            CommPortIdentifier portId = CommPortIdentifier.getPortIdentifier("COM4");
            SerialPort serialPort = (SerialPort) portId.open("MyApp", 2000);
            serialPort.setSerialPortParams(9600, SerialPort.DATABITS_7, SerialPort.STOPBITS_2, SerialPort.PARITY_EVEN);
            os = new PrintStream(serialPort.getOutputStream(), true);
            os.print("@00WD0620007050*");
            os.print("\r");
        } catch (IOException e) {
            e.printStackTrace();
        } catch (PortInUseException e) {
        } finally {
            if (os != null) os.close();
This code produces no effect on the DM area. In this code I am trying write “0070” at location “0620”. The connector and its driver are alright because CX-Programmer is working fine using the same cable.
Any pointers for this would certainly help me.
Thanks
Are you getting any response from the code by serial port?  The response should tell you what the problem is.
