Posted 26 Sep 2016 Hi Guys, Is there a way to compare two SW Projects without loading one of them in the PLC? I don't have the Hardware here and I need to check the differences between two projects. Thanks :) Share this post Link to post Share on other sites
Posted 26 Sep 2016 Which programming software are you using? Share this post Link to post Share on other sites
Posted 26 Sep 2016 GX Works 2. I have two versions of the same machine software and want to see the differences. Share this post Link to post Share on other sites
Posted 26 Sep 2016 I Managed to figure out how to do it but the mismatch part is unclear to me. Where should I look to see the differences? Share this post Link to post Share on other sites
Posted 26 Sep 2016 In your project navigation goto Parameter => Netwrork parameters => CC-Link You should have a network declared here. In the bottom there is a button "Station Information" press this. Here all the CC-Link stations should be defined here. There is a discrepancy in defined stations between project one and two Share this post Link to post Share on other sites
Posted 26 Sep 2016 Found it. Thank you so Much. What does No setting mean? What is the difference? Share this post Link to post Share on other sites
Posted 26 Sep 2016 When there is no setting this is default which means this station exists in the actual network. When it's set to reserved station. Then it exist in your program but is not actually connected yet. (future extension ) this way you do not get error on your system that this station can't be found. 1 person likes this Share this post Link to post Share on other sites
Posted 26 Sep 2016 Mate you just helped me in the biggest way possible. If you pass through Romania I'm buying you a beer :D Thanks a lot Share this post Link to post Share on other sites
