Jimbo 99
Ethernet to PLC program
5 posts in this topic
How do I read a Mitsubishi PLC program through a QJ71E71 Ethernet card mounted on the same rack?
I also have this problem and I am getting 3103 ' link para error' in q03ud PLC
These are two separate  questions:
As for the Error unless you have a  Multi CPU system you most likely have defined the wrong Io address for the ethernecard. (start I/O no).
You can check this by going to diagnostics system monitor. On top of each module the IO address number is displayed
As for the communication Question Check this post:
Edited by Gambit
1 person likes this
hello gambit, thanks for help but when I go to the Ethernet diagnostics, error is displayed ' no of module setting is incorrect'
don't go to the ethernet diagnostics check the system monitor !!!!
