johneedw
NT11S omrom panel
25 posts in this topic
Hello,
 I've a new empty  NT11S  omron HMI panel , i'm trying to download a system program to it via windows xp but when i choose  download option from NT series support tool loader, an error message appear says:(Communication error!....Framing Error) as shown in the attachment.
Help me please
The NT11S does not use a standard serial cable.  You need to make your own, or buy one from Omron.  This is the pinout:
ImofjwAAAABJRU5ErkJggg==
Dear Mr. Michael,
Thank you for kind reply.
I'd like to tell you that I've got a cable pinout  from the manufacturer of the machine as shown in the attachment which is  differ to that you typed as shown in the attachment !..
Any way, I'll make your cable pinout and tell you the result...
                                                      Thank you
Dear Michael,
I've made your cable configuration , but the problem remained the same !.. help me plz !..
Thank you very much dear Michael..
But I've a two cable configurations, the 1'st which you post and the 2nd which i got from the machine manufacturer and typed in my post
in this page.. Please advice me which one  should I depend?..
Note: I'm using (NT Series Support tool) software..
Thank you
Edited by johneedw
The one that I listed above will work.  Not sure about the other.  It is likely that the communication parameters are not set properly in your software.  (connect pulldown menu, then Comms Setting).
It's also possible that your NTSS is not communicating through your PC hardware. This is very old software (DOS based). You will have better luck using NTST. I'm not sure if Omron has a download for it but I'm sure if you contact an Omron distributor, that should be able to help you out.
He is already using NTST... he just capitalized the wrong letters.  NT series Support Tool.
RsKIqiKNkh+v8mC6K9IhYPdAAAAABJRU5ErkJggg
And even NTST is very old.  As you can see, my installation (which is the newest version) was last updated in November, 2008.
Well. now we have a starter copy in the download section....
Dear friends,
Thank you for kind replies..
I need to login to the panel configuration and see its serial port setting  to set the (RS232)port of the PC according it .
 I've try the method shown in the attachment to login but the panel does not login yet and it says only (INSTALL MODE 1.3)! ..
Help me please to login to the system menu..
        Thank you
Why are you trying to transfer the system program?  This is the operating system for the NT11S.
Because the panel is new and empty , hence I need to download it with the operating system
to run on  the machine !...Thank you
Edited by johneedw
Dears,
This is the rear of the panel, I'm asking if there is a certain setting to the SW2 DIP switch
which might support the INSTALL MODE ?.
Also, I don't know the setting of the PC serial port (COM1) which is compatible with panel's port setting!..
Help me please... Thank you
Turn Dip Switch 6 off.
The NT11S already comes with an operating system loaded.
Dear Friends,
Finally my omron panel communicated with the PC according to your's advice  and now it is functioning successfully.
Thank you for kind interest and help.
dear Mr Jojneedw
what what the solution ??
isit cable problem or what ??
This post is very detailed.
What are you having trouble with?
the same problem of (communication error - framing error )
i tried the cables above and communication settings but it doesn't work
also i updated the software and the problem is still present
Edited by Maher Salem
adding details
Are you able to put the NT11S into 'Transmit Mode'?
Do your serial port parameters match?
No i cant log into transmit mode
the serial cables and parameters are matching
I had the same problem and this topic saved my life ahaha..
I have a NT11 V1 with a broken display and I couldn't find a replacement so I bought a second-hand NT11S.
1- After having problems with the communication I did my own cable like Michael Walsh told above and all communication worked ok.
2- Downloaded application from NT11 V1 and uploaded on NT11S. After opening the application from NT11V1 you should go to TOOLS > PT CONFIGURATION > and change PT MODEL to NT11S. After, upload the application.
3- When connecting to PLC go to maintenance mode and change the baud to 19200. DONE!!!!!
That was my experience, I hope it helps someone in the future...
