nmk34
Passing a string to parameter List
2 posts in this topic
i wanted to create a small project using parameter List using an example listed in the factorytalk view manual.
in the display list selector properties under states: parameter list option I typed:
Display Canning/T{Corn_Name}, {Corn_Temp} where Canning is the display name and Corn_Name is an HMI string tag and Corn_Temp is an HMI analog tag then in the Canning display I have a string display object and a numeric display object. The string " corn" always displayed as ?????? while the numeric is displayed with the correct value of the tag. I used the same tags using parameter file and I get the correct values. am I listing the parameter list tags with correct syntax for the string?
Thanks
It is not clear to me what you're realizing.
I guess you're using FTViewSE... the syntax you wrote, should be used inside a button action...
Display List Selector instead, just needs the tags to be added in the Parameter List field, separated by comma.
Parameter list: Corn_Name, Corn_Temp
Hope this helps,
- fuzzy logic
