Bigha
Fx5 and GS2107-WTBD communication ethernet error
Hardware & software HMI -  / GT Designer 3 ver. 1.113 T PLC - Mitsubishi FX5 32 MT / GX Works3 ver. 1.019V
Error HMI shows "Comm error". i.e., The HMI isn't getting a response from the PLC. IP addresses are all correct and ping (and can be programmed) OK.
These settings are correct?
Many thanks.
Hello Bigha,
Here was changed system and my .pdf file is removed from other post.
I send you some example that i have.
As i see you  have error in "Controller type". It Shoud be iQ not FX.
I think Communication Port No Should be 5001.
Upload my program it must work
P.S As i remember for HMI GS2107-WTBD have additional GS Installer in Installation disc.
So install GS Installer. (find it)
Best regards: Altan Sadak
P0382014n2.GTX
P0382014n9PID44n16.gx3
Hi Altan! Thanks for the reply! I will look definitely!
Step 1 – download the latest version GT Designer 3 from the Mitsubishi website. I use the version 1.145 B
Step 2 - Settings for GT Designer 3
Controller Type Melsec iQ-F
Driver: Q17nNC, CrnD-700,Gateway
And other settings like the screenshot:
Step 3the settings of GX Works3:
In this project a PLC and HMI I've connected through the switch, if you use a router, then you need to add the ip address in settings. When using the router fill project occurs without a cable.
Edited by Bigha
Thank you very much Altan
can u mention the link for GT designer 3 latest version download !? i am stuck in older version of software !
it will be of gr8 help, thanks
You can get the latest version from the download section on Mitsubishi's website.
