hboyer90
RSLogix5 How to make full screen default.
Hey, here's what I assume is a pretty basic question. Every time I open a program in RSLogix5 it opens in like half a screen, like when you right click on the toolbar and select "show windows stacked". It didn't always open this way, but now every time a program is opened it automatically stacks it. Any way to make it open in full screen by default? It's just getting kind of annoying. Thanks Howard
When you close RSLogix, it should "remember" the screen size and return to that next time it is opened. To quickly get the screen sized right, stretch the main window to a comfortable size (not maximized). then click on the menu "Window" "Arrange...", select "Default Project" and click "OK". If you do that, then close it and re-open it, and it is still fouled up, two things come to mind: 1) Run as administrator at least once to make sure the software is allowed read write access to its registry entries where the user preferences are stored. 2) Shut down RSLogix. Hold Shift and Ctrl while starting RSLogix. This should reset the user preferences in the registry to their default settings and hopefully fix any corruption that may have it hosed up. Edited by OkiePC
Worked great, thanks!
