Posted 12 Jun 2015 Hello all, I have been trying to get my first C-more application to work and am pulling my hair out. I have an AB micrologix 1400 and am trying to connect it to a C-More EA9 with ethernet. I am using a cable directly from the panel to the plc. I can ping the PLC, and works well with RSlogix via the Ethernet cable. Nothing I do to the EA9 CMORE has worked yet. I have changed the ip settings several times. I can load the program with a USB and I can see it using the CMore software but I cannot transfer. AutomationDirect seems to be out of town this week and I can't get anyone to speak/talk with. There is no section on troubleshooting this as far as I have found. I have set the PC to : IP 10.0.0.65 Mask of 255.255.255.0 I have set the EA9 Panel to : IP 10.0.0.21 Mask of 255.255.255.0 I have set the Micrologix to : IP 10.0.0.10 Mask of 255.255.255.0 Thanks, Hutch07 Share this post Link to post Share on other sites
Posted 12 Jun 2015 (edited) Technical support will start at 9am Eastern time Monday through Friday and continue to 6pm Eastern time (800) 633-0405. There is a lot of assistance in the C-more Help file for how to set up the communications as well as quite a few white papers located on the Technical Support Website. Edited 12 Jun 2015 by rlp122 Share this post Link to post Share on other sites
Posted 12 Jun 2015 http://support.automationdirect.com/docs/an-ea-004.pdf Thanks for the link. I am reading this now and will post the resolution. Share this post Link to post Share on other sites
Posted 12 Jun 2015 (edited) I can now test the communication from the EA9 panel and get it to pass. I am using the exact settings as yesterday only time has passed. I am now getting PLC-498: Error code 0x100000 returned from PLC on Service. https://www.automationdirect.com/static/manuals/eauserm/appxa.pdf Edited 13 Jun 2015 by Hutch07 Share this post Link to post Share on other sites
Posted 13 Jun 2015 Finally got it. The PLC-498 was coming from an error on my end. I had a B3 in my tag list that was not in the PLC yet. Which brings me around to my other problem. I exported the tag database from the Micrologix/rs logix 500 into a csv file and the input and outputs would not upload into the cmore tag database. When I opened the csv file in Excel, everything looked fine. All i/o was there. It looks like I can use the inputs/outputs from the user manual so why don't they come in???? Share this post Link to post Share on other sites
Posted 16 Jun 2015 IIRC IO points are not supported by C-more. Share this post Link to post Share on other sites
