mustaqim90
how to write program to find max and min value
7 posts in this topic
hi. i have a problem. im using omron cx-programmer..how to write the program to find maximum and minimum value in ladder diagram using the formula (tn < tn-1) and (tn > tn-1). help me..
Hi, Which PLC do you have? Most of them have a instruction to finds the max/min value in the range. there are also some options like unsigned or sgined. You can check the max/min commands for details from help on cx programmer.
I do this often, very simply, by moving the value in a register, and comparing that value to the actual value. The comparison instruction has to be scanned first then it will compare to the value present in the previous scan. In other word the Compare instruction must be before the Move instruction in the ladder.
Use MIN and MAX functions.
What is your PLC?
