Posted 9 Dec 2014 Hey guys I need to connect an XT Controllogix L63 with a GE D400 via ethernet to send some variables for SCADA and I've never done this setting if you could tell me how I can do this would be very grateful Share this post Link to post Share on other sites
Posted 9 Dec 2014 I've never used a GE D400, but after a quick google search, it only supports a limited set of protocols (namely, ones more commonly used in power distribution/substation SCADA systems). The ControlLogix doesn't natively support any of these protocols. You have a few options: - Implement the Rockwell Modbus Sample Code (V20 and certain hardware needed) http://bit.ly/1t5jX8r - Use a Ethernet/IP to Modbus or DNP3 Gateway (Multiple vendors, I've linked to a ProSoft model) http://bit.ly/1Acn9zl - Use a ProSoft DNP3 card (or Modbus card, I've linked to DNP3) http://bit.ly/1vLW9aV Hope this gets you pointed in the right direction! Share this post Link to post Share on other sites
Posted 10 Dec 2014 thanks for the answer, Thanks for the answer if I use the second option as could communicate because I am not sure that the GE D400 talk modbus if you saw at some manual please show me which thank you very much for your time Share this post Link to post Share on other sites
Posted 10 Dec 2014 I saw that the D400 supports Modbus on this page (https://www.gedigitalenergy.com/multilin/energy/catalog/d400.htm#mm). However, DNP3 is a better protocol than Modbus anyways, so I'd suggest going that route. Share this post Link to post Share on other sites
