Posted 20 Nov 2014 hello all i searched too much but cant found please can any one tell me which software use for fx0-20mr programming for windows. and what is es and ul versions of fx0-20mr. but i have fx0-20mr only.. Share this post Link to post Share on other sites
Posted 20 Nov 2014 The software you require is GX Developer available from your local Mitsubishi supplier. You will also require a SC09 programming cable. The es and ul are the markets the units are specified for. Rodney 1 person likes this Share this post Link to post Share on other sites
Posted 20 Nov 2014 (edited) thanks mr rodney one more thing in gx developer i see in cpu Fx0(s) and Fx(n) not only "fx0".will selecting Fx0(s) cpu works for me? Edited 20 Nov 2014 by tauqeer Share this post Link to post Share on other sites
Posted 20 Nov 2014 Tauqeer, Yes if you start a new project in GX-Developer select the PLC series: FXCPU and PLC Type: FX0(s) and it will work for the Fx0. First make a simple program with two rungs or so to see if you can communicate. If not change the setting of the PLC type to FX0(N) Good luck Best regards, Theo V. 1 person likes this Share this post Link to post Share on other sites
Posted 21 Nov 2014 G X Developer will prompt you when you try to download the programmer that the selected P.L.C and the connected one are not the same. Rodney Share this post Link to post Share on other sites
