python01
Measuring motor current without VFD?
I have project where I need to measure motor current but I do not need to control the speed of the motor since it would always be running at full speed. Do I still need to use VFD to get feedback or is there cheaper way to measure the current?
Inline Amp meter that mounts to the front of the panel?
If you just want to measure the current in the PLC, and you already have thermal overloads, you can use a product like this: (http://www.redlion.net/sensors/current-sensors) Look in the "Current Transducers" area Another option is to use a Smart Overload Relay such as the E3 Plus (http://ab.rockwellautomation.com/Circuit-and-Load-Protection/LV-Motor-Protectors/E3-Plus-Overload-Relays). You can get the current feedback using communications (DeviceNet, although you can get Ethernet/IP with an adapter. Allen Bradley promises us that an ethernet model is coming out) Hope this helps.
I must be getting old. I recall when measuring motor current was standard and the questions were; can I and how do I measure this if I have a VFD. Edited by RussB
I need to feed the measurement to PLC so the E3 Plus from Allen Bradley might be the best option. Another question would be how do I measure current for device powered by 12Vdc?
I've never done this before, but after searching "DC Current Transducer" I found this: http://www.ce-transducer.com/Current_transducer.asp In particular on that page there is this: http://www.ce-transducer.com/CE-Az11-1.asp It just might fit the bill.
These work reasonably well and aren't terribly expensive. http://www.automationdirect.com/adc/Search/Search?searchquery=CURRENT%20TRANSDUCERS&cmd=Search&fctype=adc.falcon.search.SearchFormCtrl&TxnNumber=-1 Edited by Mendon Systems
