mostafa
problem about connecting Labview to Delta PLC
2 posts in this topic
hi dears i connected labview to Delta PLC with DCS Module. and i created I/O server with Modbus TCP Protocol. when i just define a Axlilury Tag, everything is ok and i can read and write on it. but problem is start when i define another variable tag. for example when i define a variable tag for output coil, and click on run button, i face whit this message:Error-1967353902 occurred at Shared Variable in X Vi.vi where is the Problem?
Hi Sparky, I am not familar with the Delta PLC but if it follows the Generic Modbus TCP standard, you can follow the guide for our ET modules. https://www.icpdas-usa.com/documents/labview_modbus_eng.pdf In the future, if you require additional IO, you can connect in the same way using our ET series modules http://www.icpdas-usa.com/et7000table.php.
