Posted 3 Jul 2014 Hi, I would like to set up a S7-315 2PN/DP with two TP900 panels and read the system clock from the PLC. The clock should also be possible to set from the panels. I have been reading the messy information given by Siemens help pages in the software (TIA V12). It's not very clear how to control the system clock from the panels, at least not for me since I'm a Mitsubishi guy. Another guy at the forum once wrote "When it comes to Siemens, information is as clear as mud" Do I need to write PLC code using some SFB's to be able to set date and time ? In wich registers can the clock data be found ? Is it possible in runtime to switch between 12 and 24 hour format ? And so on...... Share this post Link to post Share on other sites
Posted 3 Jul 2014 (edited) In such networks (single PLC and multiple HMIs), CPU is a "time master" (where master clock is). You synchronise HMI clocks using AREA POINTER (communication tab in WinCC). On screen, then you put a filed with Date/time tag, showing SYSTEM TIME. How to set master clock in PLC using both HMI? In some DB in PLC you must have a variable type DTL. Then, on screen, make a filed with DTL type INPUT/OUTPUT connecting that PLC variable from DB. Then, create a button to set one bit. Then, in PLC, when that bit is on positive edge, write that variable in PLC RTC using WRITE SYSTEM TIME istruction. Edited 3 Jul 2014 by Homer_BL Share this post Link to post Share on other sites
Posted 4 Jul 2014 Thanks Homer, I'll give it a try. But, are the date/time variables hidden in the PLC ? I'm used that I can access them directly just as easy that I read MW50 or any other integer. Share this post Link to post Share on other sites
Posted 10 Jul 2014 There are SFB's to set and read the clock Share this post Link to post Share on other sites
Posted 14 Jul 2014 Yep, found them, used them, wrote some code and it's now up and running Share this post Link to post Share on other sites
