Guest gert
MPI pinout between CP 5611 and 315-2DP
8 posts in this topic
Hi, I want to make an mpi cable between a CP 5611 mpi pc card (9-pin female) and a 315-2DP (mpi-port, 9-pin female) Who knows the right connection pinout ? Thanks
Hi, I can't remember off hand what pins are used, i think it's basically 1to1, 2to2 3to3, etc.. Good Luck Ordax
check this out ... http://www4.ad.siemens.de/-snm-0135030360-...cseus&aktprim=0 Regards by -User-
The link you have given is if you are using a PC adapter. The cable the the poster would like is from an MPI card?
If you look here, http://www4.ad.siemens.de/dnl/jAzMDg1NQAA_...3_FAQ/pin01.gif you'll get the pinout for the connector. Alternatively on the Siemens support page enter "RS485 pinout" as the search key and you'll get a load of answers which should help you.
you are right, RMA. Sorry about wrong information .... -User-
