Guest Ukrit
MELSEC A0j2 with AC220V
2 posts in this topic
I have MELSEC A0j2 and it can connect 2 source 100 v and 200 v but I have AC220V and i not sure to connect it. if you knnow, please tel me. Thank
If I remember correctly... There are 4 terminals you are interested in, two of which are marked "input" and "100/240VAC) - this is where you connect yor supply, the other two terminals may or may not have a shorting link across them, labelled "short 100v" and "open 100v" Thus if you are using 240v supply, the terminals will be empty, and for 100v they will have the shorting link If the above does not match the terminal configuration of your unit, can you please post what it is. Regards
