funfrok
Citect Alarm Logging Custom Fields
3 posts in this topic
Hello, I use SQL device for alarm logs. Alarm logging function works, records for alarms being on,off and acknowledge are created in sql table. I'm using sql file format as: {LocalTimeDate,25}{OFFDATE,15}{OFFTIME,15}{DeltaTime,10}{AckDate,15}{AckTime,15}{Name,70}{SUMDESC,120}{Priority,3}{FullName,35}{UserName,50}{Area,5}{Category,5}{CUSTOM1,64}{CUSTOM2,64}{CUSTOM3,64} All fields are recorded successfully except CUSTOM1,CUSTOM2 and CUSTOM3 fields. I tried casing like "Custom1", but it didn't work. Empty string is recorded for these fields. I'm using timestamped alarms with CUSTOM1,CUSTOM2 and CUSTOM3 fields not empty. Do you know how to record these fields? Thanks
I tested with Digital Alarms and custom fields are logged. So there is a bug in Citect which prevents logging of Time Stamped Alarms custom fields. Well done Schneider!
It looks like the problem is fixed with Service Pack 4 (Citect 7.20).
