Posted 2 May 2012 (edited) hello i have a little problem it's the first time when i use gx works 2and when i rebuild all there is a message post in result is " CHECKWARNING " i want to know how to correct this ? thank you please can sameone help me pllzzz Edited 2 May 2012 by boudarra Share this post Link to post Share on other sites
Posted 2 May 2012 Read the message, it explains it pretty clearly. Warnings and CheckWarnings are not fatal, the program still compiles and runs. Errors are fatal. You used the same output more than once. If that is by design, then ignore it. If not, fix your duplicated coils. I believe in Options you can turn off the duplicate coil check entirely if you desire. Share this post Link to post Share on other sites
Posted 2 May 2012 (edited) thank you very much i have a exemple can you tell where is the checkwarnings thank you Edited 2 May 2012 by boudarra Share this post Link to post Share on other sites
Posted 2 May 2012 Use the cross reference or device list to see what addresses are used. It is saying one of those outputs is also used as an output somewhere else, or that perhaps both labels point to the same address. Share this post Link to post Share on other sites
Posted 25 Apr 2022 What is the difference between a Warning and a Checkwarning? Share this post Link to post Share on other sites
