BAK96
Retentative timer
4 posts in this topic
Is it possible to use retentative timers in structured project in ladder mode, When doing the compile I get an error code f1028 Which states a device of the device range is set in the device /label automatic assign setting or a device which cannot be used due to system reservation is being used. I wish they would give help remedies for the compile errors in the software without having to try and look for it. But if anyone has some suggestions it would be most appreciated. M181 ----l l----------------------------------------------------(ST0 ) K10 Thanks Edited by BAK96
Hva you created stored timers in the parameters. Default = 0
If it's not what Gambit said, then go to Tools, Device-Label Automatic-Assign Setting. I bet the automatic pool took all you had configured.
to change to what from zero? I tried changed it to 16,32 or 2k, still having error.
