Posted 22 Dec 2010 I need to extend the 15 pin connector on the front of several 5/20E's because the ethernet adaptor is in the way of the memory slot. I can use a standard cable but I would like to use the proper AB attachment clip style if they aren't too proud of it. Anyone know if such a cable exists? Or what those ends with the clips are called? This cable only has to be a foot long. Share this post Link to post Share on other sites
Posted 22 Dec 2010 Not sure about the cable you want but aren't the clips you want called "sliding clips" see link below http://parts.digikey.ca/1/1/713215-conn-d-sub-latch-slide-15pos-5745583-1.html Share this post Link to post Share on other sites
Posted 22 Dec 2010 Update. I found it called an AUI cable (which makes sense considering thats what it is for) but a vendor wants $100 each cable. I'll keep looking. Share this post Link to post Share on other sites
Posted 22 Dec 2010 I'm not sure if there is something special about AB's cable but see link below for links to AUI cables http://www.google.com/search?q=aui+cable+pinout&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a Share this post Link to post Share on other sites
Posted 22 Dec 2010 The PLC-5E and 1785-ENET sidecars have a totally ordinary AUI port; there's nothing special about it and you can use any AUI extension you can find. They're uncommon in modern equipment, though, so you're either going to pay a lot or find a surplus one. Share this post Link to post Share on other sites
Posted 22 Dec 2010 Now that I have seen that AUI cables include that slider I had a little trouble finding them under 6 foot long but I did at PIMFG.com for about $9.00 Share this post Link to post Share on other sites
