Posted 21 Nov 2010 (edited) Hi all, any advice/help would be greatly appreciated, I have a Mitsubishi A1S Plc, it has a programme in it which I am wanting to keep, I have tried to access the PLC using both medoc and GX Developer, whenever I try to access, it's asks me for a password, which i don't have, I then tried the serial monitor technique which came up with nothing, I then removed the battery for 24 hours hoping to completely erase CPU, yet upon reconnection, it still asks for the password! Any help regarding finding/erasing password, or totally clearing the CPU would be highly appreciated. Edited 21 Nov 2010 by RB211 Share this post Link to post Share on other sites
Posted 21 Nov 2010 If the CPU wasn't erased by removing the battery you probably have a memory card that stores the program. Try removing both the memory card and the battery so that the program memory is erased. Share this post Link to post Share on other sites
Posted 21 Nov 2010 You wouldn't happen to know where the memory card is located on an A1s by any chance would you? Share this post Link to post Share on other sites
Posted 21 Nov 2010 You should be able to see if any memory card is installed when you open the lid of the CPU (you opened the lid to remove the battery right!? you should be able to see if there is any card installed).... Share this post Link to post Share on other sites
Posted 21 Nov 2010 I'm sure there was nothing in there that resembled a memory card, will have another look when I get in though! Share this post Link to post Share on other sites
Posted 22 Nov 2010 Nope, definitely no memory card in there! Share this post Link to post Share on other sites
Posted 22 Nov 2010 When I'm thinking about it I don't think that the A1S supports memory cards, but I'm not 100% sure.... It's been a long time since I looked at the A1S CPU.... Strange that the PLC memory isn't cleared after you removed the battery... Share this post Link to post Share on other sites
Posted 22 Nov 2010 Unless it was not powered down :) Share this post Link to post Share on other sites
Posted 22 Nov 2010 (edited) Why are you trying to delete the memory of the CPU by disconnecting the battery. You will lose your program if it's not on a EEPROM. If that doesnt matter just clear the PLC via medoc or GX Developer. 'p.s. If you are using an A1SH the EEPROMis on the side of the CPU not in the front like the a1s. Edited 22 Nov 2010 by Gambit Share this post Link to post Share on other sites
Posted 28 Dec 2010 You can hack password follow as manual on attached file, I have done for my A173UHCPU already. I confirmed, it can use. Share this post Link to post Share on other sites
Posted 29 Dec 2010 Hacking/Cracking is forbidden in this forum! Read the "Terms of service"!! Please clear your post! Share this post Link to post Share on other sites
