pops
ACE(CPU3640) to Compact Logix L23E Ethernet Connection
2 posts in this topic
Has anyone been successful with the following: I am trying to set-up some communication between the ACE (CPU3640) and a Compact Logix L23E plc using Ethernet connection. This plc has been set up to map the data block as PLC 3,5/ SLC Mapping. I am looking for any assistance I can get specifically on ( within the ACE): 1. The Eth1. Port setting 2. The PLC Table [231] settings Any other guidelines will be appreciated.
I try only to define ModBUS protocol with ACE, and it is working fine, otherwise, the default working protocol in ACE is MDLC (Motorola Data Link Communication) which is I think not supporting your case. Cane you mention which protocol you are trying to deal with in order to help in finding solution.
