Posted 28 Sep 2009 I've installed CX-One ( latest with all updates ) on a laptop that is running Windows XP Pro 64bit. The USB driver that ships with CX One does not work. Omron Canada tech support says that there is no USB driver available for a 64bit system. Has any one else run into this? Are there any work-arounds? or do I need to downgrade to 32bit? Share this post Link to post Share on other sites
Posted 29 Sep 2009 You will need to downgrade to 32 bit OS. I don't believe there is any 'compatibility mode' that can support the 32 bit drivers in a 64 bit OS. I would love somebody to prove me wrong! Share this post Link to post Share on other sites
Posted 30 Sep 2009 You can also load your program through a serial port. If your laptop doesn't have one, a cheap usb to serial adapter (make sure 64bit drivers are available) will work. If you're plc has ethernet, then that will also work. If you want to use USB, then a 32bit operating system is a must afaik. Share this post Link to post Share on other sites
Posted 30 Sep 2009 CX-One requirements. CX_One__Sist.Operat_.pdf Share this post Link to post Share on other sites
Posted 30 Sep 2009 I will be installing a 32-bit OS. Has anyone tried running CX-One on XP Pro 32bit in Virtual Box (or VM Ware) within Vista Ultimate x64? This is what IT is advising me to do. They say it should work. Share this post Link to post Share on other sites
Posted 1 Oct 2009 Thats what they always say, until it doesn't, then what do they do?? Share this post Link to post Share on other sites
Posted 1 Oct 2009 I don't think a virtual machine is going to help. The 'outer' OS (64 bit) is what uses the driver. The 'inner' OS has access to the port, but does not use the driver. Share this post Link to post Share on other sites
Posted 10 Nov 2009 (edited) I have Windows 7 Home Premium 64bit laptop, got CX-Programmer, CX Integrator, and CX Designer all working using a new 64 bit chipset serial adapter and 64bit drivers. This is working as com4. Still haven't been able to get USB direct to device ( CX-Designer & NE1A Safety Controller ) working yet. Still working on these 2. No Virtual Machine running or available on Home Premium. Edited 10 Nov 2009 by dococ Share this post Link to post Share on other sites
