Phil Kennedy
1 Button Latch Problem
A colleague has phoned me asking me how to create a block which will work as a latch circuit, but the circuit needs to be started, and stopped using the same push button. I have suggested this; ____M0.1______ ----[i0.1]--(p)-------I Set I I I I I -[i0.1]-[m0.1]--(p)--I Reset I I_____________I Unfortunatly im sat in an airport so I have no way of testing this but will this work? If not has anyobody got any ideas on a simple way of doing this, so that pushing the button once will Set and address then pushing it again will reset. Thanks! Edited by Phil Kennedy
Hello Phil. Not easy to see what your code does, because empty spaces has been stripped out. But I think it does NOT work, because the M0.1 in the second rung will immediately reset itself. "flip-flop" is the magic word. Try to search for it.
Most PLCs have a function for this. Which Siemens PLC are you using?
Hi Phil, I hope this is what you are looking for: A I0.0 FP M0.0 AN M0.2 S M0.2 A I0.0 FP M0.1 AN Q0.0 R M0.2 A M0.2 = Q0.0 Kind regards Arturas Edited by Arturas
try this: A I 0.0 FP M 0.0 JCN _001 AN Q 0.0 = Q 0.0 _001: NOP 0 Best regards
