guillencito
RsLinx works with Windows CE?
4 posts in this topic
Hi all! After a long time... now I am back in the source... This amazing forum Now I'm developing an application with VB.Net and WinCE (handheld PC) and I need to communicate with a SLC 500... Usually, if i'm working in a PC, I install Rsling and configure a driver(serial, ethernet, DH or whatever) but i don't know if exists a RSLinx version for this environment, or if normal rslinx can work Could you tell me if it is possible?? Thanks in advance!!! Best Regards from Mexico!
The following http://www.rockwellautomation.com/rockwell...inx/sysreq.html lists the system requirements for RSLinx. Windows CE is not mentioned, but is the OS for some flavors of Panelview. RSLinx Classic Microsoft Windows 2003, XP SP2, 2000 Microsoft Windows NT Version 4.0 (Service Pack 3 or later recommended), Windows Me (Millennium Edition), 98 Ethernet interface, USB, or a Rockwell Automation Network interface RSLinx Enterprise Microsoft Windows 2003, XP SP2, 2000 PanelView Plus, VersaView Ethernet interface, USB, or a Rockwell Automation Network interface you might check out http://www.automatedsolutions.com/ I've used their product on several projects and windows OS platforms but never CE.
There are CE Versions of RSlinx for use on the PavelView CE Boxes. However you cannot install it and run it on ohter CE Platforms. Comm
If you can confine yourself to DF1 you might check this application http://sourceforge.net/projects/abdf1
