Posted 29 Sep 2008 Hello! I have a Tsx Momentum plc, wich was used once by another programmer. Now I can not connect to it by modbus and download the program because I don¨t know the address of the plc (PLC Node). Can I set the PLC to factory settings and how do I do that? What is the default address then? Please help Thank you Share this post Link to post Share on other sites
Posted 30 Sep 2008 You can remove battery and power down. The program will be erased in 5 minutes (if it not in flash). The default settings: PLC Node 1, baud rate 9600, 8 data bit, 1 stop bit, even. Share this post Link to post Share on other sites
