Posted 28 Aug 2007 Hi all, i do like to have some advice for this FBC instuction. i'm still confuse after study the manual. please give me some guide for it. will be better if have sample program. the reason i use this instruction is i can always checking the 6 out of 12 wafers reject condition. Thank. Share this post Link to post Share on other sites
Posted 29 Aug 2007 Hi, i understand in this way: I use to search wath alarm condition has been triggered. I have about 300 alarms conditions, in the source i create an array (same size of alarm number, in my case is almosto all 0's). The reference array contain my system alarms (Always 0, and 1 when triggered). I use the search mode "One mismatch a time"; then i put to work cyclical. When one alarm is triggered, the position of Result Control, shows in what bit was found the diference o mismatch. I use this number to display a alarm message on a PView. Then i unlatch the .FD bit, to continue searching any mismatch between the source and reference. I hope it help you. Isaias Frias Rguez Share this post Link to post Share on other sites
